esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
Durga
Mar 06, 2017NETGEAR Expert
Hi Zappullae,
We are hitting a corner case where the packets are stuck in the firmware. This will happen with some smart phones (especially recent ones) and specific applications running on them coupled with bad RF environment and high channel utilization. We made minor changes in the software to handle this particular condition.
Has the new firmware fixed your problem?
Thanks,
Durga.
zappullae
Mar 06, 2017Aspirant
It takes a time to know if it works. So far so good. We'll know in about 2 weeks to a month.
