esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
zappullae
Mar 13, 2017Aspirant
Similar, Its slower all the time. Before the patch it was faster until it hung up now its slower and takes longer to hang. One thing I can saw is as I have reported here in the past I bought this "high end" WAP because my NETGEAR WNDR3700 huing up and I had to keep rebooting it the same way the 660 does. I appretiate your offer of help bit its not possible to do a remote session because I've been messing with this for over a year and I'm done with it. Time to buy a WAP that works.
zappullae
And it just hung up again. The fix made it worse. I took it down. Terrible device.
