zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
esaym
Feb 06, 2017Aspirant
Is that with AMPDU disabled? I haven't had a problem, other than AMPDU disabled means I only get 802.11g speeds....
