zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
zappullae
Feb 06, 2017Aspirant
esaym. AMPDU is enabled. I spent a lot of $ on this WAP specificly for speed its supposed to give. Its kind of pointless to use it in a nuetered mode when 802.11g devices are so inexpensive.
esaym
I totally understand. Disabling AMPDU is not the final solution I want or will accept. But it does get one up and running. I don't know what your symptoms were, but at least for me, I only had issues when mobile phones where connected to the AP. I had all mobile phones connect to the 2ghz radios in which I disabled AMPDU, and forced 20mhz channel width. Everything else was left at default. For 5ghz, I have all other non-mobile devices, laptops, desktops etc, connected to 5ghz where AMPDU is enabled. Everything else is default except I forced 20hmz channel width for 5ghz as well (I find that 40mhz channels enabled puts random lag sometimes).
But yes, I bought the 660 because I only needed something faster than 802.11g and wanted something that had been out for a few years and thus would be stable and bug free. Sadly not what I got since complaints against these APs for the same issues go back for 3 years and they are still unfixed. Sadly there isn't really any other APs that are purely standalone. There is the Ubiquiti stuff but they all require a separate controller to be configured or you have to install an app on your phone which is not what I want.
