zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
RaghuHR
Mar 08, 2017NETGEAR Expert
Hi All
Would like to know the feedback on the patch image if you have installed it?
Thanks
Raghu
zappullae
Mar 08, 2017Aspirant
I installed it but it can take a month before I know if it works.
Here's another thread on this subject
https://community.netgear.com/t5/Business-Wireless/WNDAP660-Connectivity-Issues/td-p/1194274
- zappullaeMar 12, 2017Aspirant
So far it hasn't hung up but its unsuablly slow. The propgress bar on FireFox (Samsung tablet) get to the place where it used to hang and pauses. Then 75% of the way and pauses. An Amozon product page takes forever to open. Unusable.
Well now it looks like I spoke too soon. The WAP had been slowing down and now its hung up. I'm done with this POS.
- zappullaeMar 13, 2017Aspirant
And it just hung up again. The fix made it worse. I took it down. Terrible device.
- zappullaeMar 15, 2017Aspirant
I'm sorry too. I'm only going to try one more thing, a factor reset and reconfig. If it hangs again its going on eBay.
