zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
Durga
Mar 15, 2017NETGEAR Expert
Dear zappullae,
We are sorry to hear that the fix didn't address your specific problem, but good to see that some users accepted the solution. Our support will get in touch with you to help you out.
Thanks,
Durga.
zappullae
Mar 15, 2017Aspirant
I'm sorry too. I'm only going to try one more thing, a factor reset and reconfig. If it hangs again its going on eBay.
