mmates
Feb 27, 2025Initiate
Recommended Solution to Cover Very Large Outdoor Area
Hello. I am looking for guidance on a Wi-Fi purchase to support a Magic Leap Augmented Reality presentation with an extremely large outdoor area. I currently use a Nighthawk LTE Mobile Hotspot Route...
Feb 27, 2025Guru - Experienced User
Suppose your business relies on it to ensure the presentation goes smoothly and without issues. In that case, it might be time to contact Netgear business for collaboration rather than using the member support forums.
I'm not sure if/what mod would be best for this. Any ideas DarrenM ChristineT
- mmatesFeb 27, 2025Initiate
plemans I agree with you and thanks for copying others. I did email [email protected] for a recommended purchase. I felt the need to expand my search from experienced guru's like yourself though. I just emailed NETGEAR Business Solutions too.
- plemansFeb 27, 2025Guru - Experienced User
When it comes to large installations, a proper design is going to be key. I wouldn't mix consumer/business gear because that can cause its own issue. And that is a significant area to cover if you're planning on covering it all. Plus if there's other signals present. Lots of variables. I've setup a few mesh systems for covering large areas but no where near that size
