wpslo's avatar
wpslo
RMA telephone number for the UK
Does anyone know the number?
The Support / Contact Us will not provide a number.
BTW My WAP died after attempting a firmware upgrade to v3.6.9 you have been warned!
  • Hi John,
    I have an RMA!
    I used the UK support number - 0344 875 4000 and was put through the tech department.
    We agreed that I had tried eveything to revive the 350 and an RMA was then duly issued.
    Thank you for your interest and help.
    Nick..
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi wpslo,
    Once you are already on the NETGEAR support site, you may need to create a chat / case online first so that the contact number for your country will be provided and also please be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification.  If ever the device is still under warranty, an online replacement will be provided.
    • wpslo's avatar
      wpslo
      Hi John,
      Thank you for replying.
      I have a problem creating a chat / case online.
      My registered products list does not show the WNDAP350 but when
      I try to register it I get the reply that it is already registered.
      That is as far as I can get.
      Regards, Nick.
      • JohnC_V's avatar
        JohnC_V
        wpslo,
        Please use the same email address that you used on registering the device or if it still not going to work. Please try opening a case using this option "Get answers about NETGEAR products before I buy". We are just going to use this option in order for us to create a chat / case online but once you already have a support expert, please let them know the status of the WNDAP350.
ProSupport for Business
