mspeculatrix
Jun 25, 2022Guide
routerlogin.net page rendering blank
I'm trying to set up a WAC564 that I haven't used in a while. I've factory reset it (more than once). Its access point (NETGEARxxx-SETUP) appears okay and I can connect to that. But when I go to www....
mspeculatrix
Jun 25, 2022Guide
I tried Edge in a Win11 VM. Same result. It's not a routing problem because I am getting the page code. It's just not rendering correctly.
I should add that, if I leave the blank white page loaded, after a while I get a message about some kind of time-out and the page reloads – I think to some kind of login. But it's still just blank, so hard to tell.
mspeculatrix
Jun 25, 2022Guide
Okay, this is weird. Still getting a blank page at www.routerlogin.net. By if I go to 192.168.0.100 I get a login page. Trouble is, I've no idea what the password is.
I've done a reset three times now - getting the rapidly flashing amber light each time. Shouldn't that have cleared the password and reset to 'never been used' mode?
