Accuphaze's avatar
Accuphaze
Scheduling for fix canal 5G
Hello! If scheduler is enabled, it incorrectly saves a fixed channel on 5G. Instead of 44 or 48, 36 is set. To set a fixed 44 or 48, you need to disable the scheduler! Correct your mistake. I.e. it i...
ProSupport for Business
