sclawrenc's avatar
sclawrenc
Apprentice
Jun 08, 2021
Seamless Roaming Supported Access Points or Routers
Hello Netgear Community,
Does anyone know if you can use two Business Essentials Access Points mode with successful seamless roaming betweens access points with VoIP calls?  For example, maybe two WAX204 or similar?
My RBR50 and RBS50 do it fine, but I'm considering going to AX so looking into either a different (dual band) mesh system or picking up a couple of Business Essentials access points that support seamless roaming on VoIP.
Thanks in advance.  Smiley Happy
S
1 Reply
  • schumaku's avatar
    schumaku
    if you are seeking full seamless roaming, focus on WAX610, WAX620, WAC540, and the like in combination with the Insight cloud management. The Essentials are intended for standalone deployments mainly.
ProSupport for Business
