daleksic
Mar 20, 2021Follower
Second AP no connection
I just added a WAX610Y to my existing WAX610. Everything is online and connected, however no devices connect to the outdoor AP. I have devices barelly getting a connection on the WAX610 and it seems ...
schumaku
Mar 21, 2021Guru - Experienced User
daleksic wrote:I just added a WAX610Y to my existing WAX610.
Tell us a little bit more. How is this (assumable) wired network configured?
daleksic wrote:Everything is online and connected,
As per Insight, and/or based on the WAX dashboard?
daleksic wrote:...however no devices connect to the outdoor AP.
Same SSID and security configured on the APs?
daleksic wrote:I have devices barelly getting a connection on the WAX610 and it seems they refuse to switch over to the closer AP.
Well, if no device can associate with the WAX610Y it's a little bit much to expect any kind of wireless hand-over or roaming. There must be another explanation.
Are the wireless SSIDs (resp. the BSSIDs/radio MAC) on air and visible? Are the wireless radios turned on at all? If you have access to an Android phone, consider to try the (Netgear) WiFi Analytics (-> Network Status) or WiFi Analyzer, and open the "tree" under the SSID - there you should see the BSSIDs (MAC ID, misleadingly designated Mac ID on the Netgear App).
If the AP Ethernet MAC is say 94-A6-7E-xx-xx-5F the radio MACs are ending on -4x and-6x when I have it right. Each SSID (or for specific applications there will be additional special "hidden" ones on air) does get a dedicated radio MAC on each radio.
