yodamin's avatar
yodamin
Segregated Guest WIFI - locally managed WAX630E - help please
Hi,   My equipment: Netgear_GS116PP / NetGear_JGS616 / Pfsense Firewall   The NetGear_JGS616 switch (old) is currently in use until I have time to setup the Netgear_GS116PP switch (new)   It's ...
  • schumaku's avatar
    Jan 05, 2024
    The GS110PP is an unmanaged switch, no config options, so no VLAN support.
    The JGS526 is a Web configurable Plus switch with VLAN support, same apply to the WAX630E and the Pfsense firewall. Your learning has to go towards configuring the Pfsense for supporting an additional network, ideally on a VLAN, with a dedicated IP subnet, including DHCP service, ...
    Said this: The data has to flow from the Pfsense to the JGS516, on either a dedicated port and network, or as a tagged port. The WAX630E must be conected to a port which (in addition to the local LAN subnet, also in use for the network admin) has to be configured as a tagged network for the guest network.
    It's not difficult - just needs some learning, trial-and-error. As we're on the Netgear community here, most don't have in-depth experience on Pfsense - so take this as design and implementaiton ideas.
    One thing that hurts my hopes for good performance a little bit: The WAX630E is a capable, multi-band AP, with a 2.5 GbE wired uplink (optional with a trunk with two GbE ports in a LAG).
ProSupport for Business
