Fred_77
Feb 11, 2025Follower
Select SSID by device
Hi,
I have 5 SSID (Separate Vlan) with 40 AP (WAX610 or WAX630E) and i would like assign SSID just for some AP but not all SSID on all AP. Is it possible to done that ?
May be if i don't assign the vlan corresponding to the SSID the AP will not present the SSID ?
Best Regards
Frédéric
1 Reply
Insight cloud managed: Tend to say no.
Locally administered: Nothing that stops you. But for what purpose you seek this non-standards config?
