dbrewe
May 04, 2022Aspirant
Setting min. client RSSI for WAC510 AP
I have a couple WAC510 APs and I would like to configure load balancing, specifically the minimum client RSSI parameter. I think I understand the basic concept, namely that if a client RSSI falls bel...
JohnC_V
May 20, 2022NETGEAR Employee Retired
Hi dbrewe,
Welcome to our community! 🙂
As per our engineering team, The client RSSI mentioned in the load balancing is a positive scale value. It is calculated using the following formula:
Positive Scale Value = 95 + (Wireless client RSSI in negative value)
example:
If a client RSSI -45, then the positive scale value is 50.
John
NETGEAR Community Team
