KSammut's avatar
KSammut
Tutor
Apr 30, 2020
Setup WC7520 with WNDAP360 in home Network
Hi All,   Since I have been in lockdown here in the UK with my family I decided to upgrade my existing wireless network which consisted of 3 x  WNDAP350 to a better system.   I found on eBay a WC...
  • KSammut's avatar
    KSammut
    May 02, 2020
    I have managed to resolve this by putting firmware version V2.2.11 onto the access point, which makes the access point completely configurable and does not need a controller.
    The WNDAP360 can be used standalone with security, and independently configurable !
    This makes this ideal for my home use and I now have 5 wifi access points from my Netgear POE switch with unique IP addresses which I have configured from within the web admin of the access point.
    Yes its a little pain to change security settings in each access point, but for my home use, its great. Now got 100% signal in every room and in the garden :)
    WC7520 now making its way onto eBay after a factory reset.
    Onto my next lockdown project.
    Regards
    Kev
ProSupport for Business
