coxbuell
Feb 10, 2017Tutor
Specific need - FVS318N
Hi, I used a FVS318N on an installation. THe wifi is not strong enough for our use. I was wondering if we can simply change an antenna by a stronger one? If so where can I find this accessory? ...
- Feb 13, 2017
The WNAP320 would be fine. Be reminded that it supports the 802.11b/g/n wireless standards and that is within the 2.4GHz band. It also supports the IEEE 802.3af standard (PoE).
Currently, NETGEAR does not have a PoE injector. I suggest you to use a PoE switch like the GS105PE or GS110TP.
DaneA
NETGEAR Community Team
coxbuell
Feb 12, 2017Tutor
Hi,
Thanks for your answer.
The WND930 looks too big for our needs.
About the POE necessity, without changing all the installation,I may add something like "Netgear Prosafe GS105PE-10000S - 5-Port" to be able to put another antenna.
Do you have something smaller (and cheaper) than the WND930 just to boost a little bit the signal ?
Thanks again for your help.
Best regards,
NC
coxbuell
Feb 13, 2017Tutor
Following my reserach, I found this : Netgear WNAP320.
Do you think it will be OK?
Another question. Instead of another Poe hub, is there some POE injector in Netgear material.
Thanks for your help.
Best regards.
NC
