Dj_Scott
Jan 27, 2017Aspirant
Splitting WND930 antennas between indoor and outdoor.
Hi! Question. I have a bunch of 30X30 sound stages (a metal hangar). Need to provide internet inside and outside. Solid connection to up to 20-50 clients. I want to mount WND930 inside the ha...
- Feb 13, 2017
Sorry. I can not acsept it as a solution. Beacause nether thre solution notr the explanation why in is "impossible" was provided. And even if it was - you where wrong in the first place. As for the acseptable solution - I went ahead and bought WND930 and tested the seperate antenna placement.
And guess what - it worked. Antennas seperated in to two zones work perfectly!
BTW the final call was to switch the intire operation to Cisco. Just so you know.
DaneA
Jan 30, 2017NETGEAR Employee Retired
Hi Dj_Scott,
Welcome to the community! :)
The internal and external antennas of the WND930 cannot be used at the same time. The possible setup that I can suggest are the following:
a. 2.4GHz / 5GHz Point-to-Point Wireless Bridging using internal antennas - This requires 2 WND930 and this will give approximately a 1 mile / 0.75 mile wireless range (2.4GHz / 5GHz respectively). Of course, the 2 WND930 should be within line-of-sight to each other. Kindly read pages 37-39 of the WND930 reference manual here on how to set up Point-to-Point Wireless Bridge.
b. 2.4GHz / 5GHz Standalone access point using external antennas - Since its standalone, it just requires 1 WND930 and this will give approximately 1500 feet / 1000 feet (2.4GHz / 5GHz respectively) wireless range. Kindly read pages 24-25 of the WND930 reference manual here on how to connect external antennas and select the external antenna option via the web-GUI of the WND930.
DaneA
NETGEAR Community Team
