Dj_Scott
Jan 27, 2017Aspirant
Splitting WND930 antennas between indoor and outdoor.
Hi! Question. I have a bunch of 30X30 sound stages (a metal hangar). Need to provide internet inside and outside. Solid connection to up to 20-50 clients. I want to mount WND930 inside the ha...
- Feb 13, 2017
Sorry. I can not acsept it as a solution. Beacause nether thre solution notr the explanation why in is "impossible" was provided. And even if it was - you where wrong in the first place. As for the acseptable solution - I went ahead and bought WND930 and tested the seperate antenna placement.
And guess what - it worked. Antennas seperated in to two zones work perfectly!
BTW the final call was to switch the intire operation to Cisco. Just so you know.
Dj_Scott
Jan 30, 2017Aspirant
The question was "can I seperate 2 antennas to one zone (inside) and 2 antennas to the other (outside)
DaneA
Jan 31, 2017NETGEAR Employee Retired
- DaneAFeb 05, 2017NETGEAR Employee Retired
There is no option in the web-GUI of the WND930 where you could specify any of the 4 external antennas to be in one zone (either inside zone or outside zone). The best option is to place the WND930 with external antennas to a place where its in the middle of the indoor and outdoor premises. Then, create a wireless network for both 2.4GHz and 5GHz bands.
DaneA
NETGEAR Community Team
