Dj_Scott
Jan 27, 2017Aspirant
Splitting WND930 antennas between indoor and outdoor.
Hi! Question. I have a bunch of 30X30 sound stages (a metal hangar). Need to provide internet inside and outside. Solid connection to up to 20-50 clients. I want to mount WND930 inside the ha...
- Feb 13, 2017
Sorry. I can not acsept it as a solution. Beacause nether thre solution notr the explanation why in is "impossible" was provided. And even if it was - you where wrong in the first place. As for the acseptable solution - I went ahead and bought WND930 and tested the seperate antenna placement.
And guess what - it worked. Antennas seperated in to two zones work perfectly!
BTW the final call was to switch the intire operation to Cisco. Just so you know.
DaneA
Feb 13, 2017NETGEAR Employee Retired
Let us know if you have further questions. Otherwise, if ever your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Dj_Scott
Feb 13, 2017Aspirant
