THarlin
Feb 22, 2018Aspirant
Unable to update WAC720 firmware
Device is at firmware version 3.6.12, latest available is 3.8.3. When I try to upgrade to that or other earlier versions I get "Firmware upgrade has failed. Please ensure that valid entries were spe...
- Feb 26, 2018
Glad that you are able to figure out what the issue is. Please accept this as soultion if you are satisfied.
Thanks,
Raghu
RaghuHR
Feb 22, 2018NETGEAR Expert
Hi Thomas Smith
Welcome to the Netgear Community. Could you please double check the following? We would like to see what error you are seeing on the screen. Could you please paste the screen shot?
Thanks,
Raghu
Upgrade Procedure:
- Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
The Firmware File name after extracting is WAC720_WAC730_V3.8.3.0.tar
Download Link: http://www.downloads.netgear.com/files/GDC/WAC720/WAC720_WAC730_V3.8.3.0.zip - Login to the AP web interface.
- Select Maintenance > Upgrade > Firmware Upgrade
- Click the Browse button and locate the image (.tar) upgrade file.
- Click the Apply button to initiate the upgrade process.
During the upgrade process, the wireless access point automatically restarts. The upgrade process typically takes several minutes. When the Test LED turns off, wait a few more seconds before doing anything with the wireless access point.
- THarlinFeb 22, 2018Aspirant
Thanks for the reply. But the error on my screen is exactly as stated in the original posting. If I were to take a screenshot it would add no additional information.
- THarlinFeb 23, 2018Aspirant
Also, perhaps I should mention that I have updated this unit's firmware successfully at least twice in the past.
- RaghuHRFeb 26, 2018NETGEAR ExpertWhen you use wrong firmware or corrupted file then you can see such kind of error messages. Could you please retry downloading the latest from the web and give a try? Thanks, Raghu
