csteel
Jan 28, 2021Tutor
Understanding the AirBridge
I want to setup some wireless security cameras to our garage but currently our home (base) wireless signal is out of range. The garage (target) is about 100 yards away. I have been researching the WB...
Jan 28, 2021Guru - Experienced User
The WBC502's don't rebroadcast so something would need to connect to the 2nd wbc502 to broadcast the signal to the cameras.
So you'd need to go:
Arris--->tplink archer--->WBC502--------------->WBC502----->wireless access point---->camera's.
- schumakuJan 28, 2021Guru - Experienced User
Go with two AirBridge as suggested by plemans . While there is a short range 2.4 GHz wireless AP for local management only, you need to add a local AP in the garage.
Some alternate approach to a wireless bridge set-up could be pulling in a fiber, and a friendly fiber installer to splice on the wall-connectors 8-)
- csteelJan 28, 2021Tutor
Thanks plemans! Super helpful. Also, the WBC502 has to have a minimum of two (master & satellite) devices for it to work. You can't just use one to blast a signal up and connect that signal to a seperate AP?
You could use just one and an AP. However, for the usage with surveillance video streaming, I would avoid sharing an AP radio for concurrent front end streaming (cameras) and backhaul (wireless link) - because this will happen sequentially, and not in parallel.
