csteel
Jan 28, 2021Tutor
Understanding the AirBridge
I want to setup some wireless security cameras to our garage but currently our home (base) wireless signal is out of range. The garage (target) is about 100 yards away. I have been researching the WB...
Jan 28, 2021Guru - Experienced User
The WBC502's don't rebroadcast so something would need to connect to the 2nd wbc502 to broadcast the signal to the cameras.
So you'd need to go:
Arris--->tplink archer--->WBC502--------------->WBC502----->wireless access point---->camera's.
schumaku
Go with two AirBridge as suggested by plemans . While there is a short range 2.4 GHz wireless AP for local management only, you need to add a local AP in the garage.
Some alternate approach to a wireless bridge set-up could be pulling in a fiber, and a friendly fiber installer to splice on the wall-connectors 8-)
