SVL123
Mar 22, 2021Initiate
Unique Sitauation
Hi all, So i have what i think is a unique situation. I am tryng to get full wifi coverage throught my Chicken Shed. The shed is 300ft (91m) x 60ft (18m). It is clad in metal with a metal roof. ...
Mar 22, 2021Guru - Experienced User
That size isn't unreasonable to cover with one device. but you'd want it in the shed and centrally located.
If you've already got a router outside the shed, you could get an outdoor rated access point that runs of POE (power over ethernet).
Simply run an ethernet cable to the AP (you'd add a power injector to power it by the primary router).
The WAX610Y is a outdoor rated, POE access point.
https://www.netgear.com/business/wifi/access-points/wax610y/
- SVL123Mar 22, 2021Initiate
Hi Plemans,
Thank you for the quick response. This seems like it could be an ideal solution. I will look into it further from the links you posted and post an update if and when i sove the problem.
Thank you for your help in this.
S
- plemansMar 22, 2021Guru - Experienced User
Probably cheaper and easier to run an ethernet cable than trying to install a power box.
Hope it works for you
- schumakuMar 22, 2021Guru - Experienced User
A PoE+ (802.3at!) can be installed outside, so only the network cable needs to go to the middle of the shed so there will be low power only.
Depending on the area you are located eg. ref. the amount of thunderstorms, some Gigabit and PoE+ capable surge protection device with a good grounding might be advised. Don't want to hear from grilled chicken ex. factory aehm shack!
Keep in mind these outdoor access points can take some rain or snow, but no high-pressure cleaning. Probably any normal office rated PoE+ unit like a WAX610 installed in a Wireless Access Point Enclosure w. NEMA 4 or higher protection class should be considered.
