Hannelore1
Feb 14, 2022Tutor
Using a WAC720-100NAS in Europ. Cant join Ensemble of other 6 APs
Hi, we bought two WAC720 AccessPoints on amazon.de to expand our other 6 WAC720. After some hours it seems impossible to join them into the Ensemble of the other 6 APs. They never appear there (fir...
Feb 14, 2022Guru - Experienced User
Not sure 100% as I'm in the US and don't have the product but I'd imagine you have to be on the same region to link devices.
I know on the consumer stuff here, its locked to the NA regionl. You used to be able to telnet in and use the burnsku command to change regions. Not sure if that device still has telnet enabled or not. If its enabled, you could try it.
