Chris480
Aug 16, 2019Aspirant
WAC730 Ensemble firmware upgrade issue - Access Denied
I've just upgraded my WAC730 AP's ensemble from 3.9.0.3 to 3.9.1.0 when I try and log on now I get the following message after entering the log on credentials.
400 Bad Request
[Access Denied] Third party application is trying to access AP
Any ideas how to get around this?
Thx
Chris
Chris480 That is correct.
there is no option to set the FQDN in Configuration>Ensemble->Managment (IP address) this has to be in the form 192.168.x.x
- Chris480Aspirant
Thanks for replying. following on from your suggestion I have found that I can log into the WAC730 if I put the address in the form 192.168.x.x . However, if I use wireless1.gnome.co.uk. I get the login page but putting in the username and password I get the
400 Bad Request
I have both forward and reverse lookup in the DNS I have also tried clearing the browser cache but it did not make any difference. But at least I can get in now. As I said it was fine with 3.9.0.3 but I got this problem as soon as I upgraded to 3.9.1.0
Chris
