Chris480
Aug 16, 2019Aspirant
WAC730 Ensemble firmware upgrade issue - Access Denied
I've just upgraded my WAC730 AP's ensemble from 3.9.0.3 to 3.9.1.0 when I try and log on now I get the following message after entering the log on credentials. 400 Bad Request [Access Denied] ...
Chris480
Hi,
Many thanks this has fixed the direct access to the AP's via FQDN. However, one last problem remains which is that you can set the IP Address to Manage Ensemble (IPv4). If you go to the FQDN for this then you get the same error as before. I assume this is because there is no option to set the FQDN in Configuration>Ensemble->Managment (IP address) this has to be in the form 192.168.x.x
Thx
Chris
RaghuHR
Aug 16, 2019NETGEAR Expert
Chris480 That is correct.
- Chris480Aug 16, 2019Aspirant
Ok. Many thanks for your time. Worth adding the FQDN for the ensemble in a future release.
Chris
