dheerema's avatar
dheerema
Very large home; Considering (2) AC3000 routers at each end, both connected with CAT6. Thoughts?
  I need to set up wifi in a very large house that is already wired with ethernet.  Considering getting two exact same AC 3000 routers, and setting one up as an AP.     To extend into the yard, as...
  • JohnRo's avatar
    Mar 22, 2016
    Hello dheerema,
    Welcome to the community!
    If the networks are not going to overlap, I think its fine. If you are looking to create roaming wireless (single SSID, seamless connection within areas covered by the APs) what you need is a wireless controller (ex. WC750) and a few APs  like the WNDAP360, WNDAP350 or WNDAP660. This will let you have a seamless wireless network with only a single SSID all over the area and the best part is a much easier management on all APs. You can also choose APs with ensemble functionality (WAC720, WAC730), basically the same conceprt as using a wireless controller but eliminating the wireless controller itself, so this is much cheaper.
    Let us know if you have more questions.
    Thanks,
ProSupport for Business
