Guzzialfa
Nov 14, 2021Tutor
Considering a CAX80 Purchase -
I am contemplating the purchase of the Netgear AX6000 (CAX80) Cable Modem with WiFi 6 Router. Before I do I have two considerations that are make it or skip it considerations. For Home and Business use (Work from Home and Non-Profit support work).
I have two (2) Netgear 24 Port Gigabit Ethernet Switches. A Model #: JGS524 fanless model and the earlier version with fan on a Cox ISP.
I use one upstairs and one downstairs where the Cable Modem and current Router are located. Are these two Switches 100% combatible with the CAX80? As in can I plug one into its own individual port on the Cable Model/Wifi 6 Router?
I have too many devices that benefit from a wired connection where priority is bandwidth - two Roku devices connected to ethernet ports on TV's, Blu-Ray with Ethernet connectors rather than WiFi. Laptops and desktops with both Wired and Wireless connections available. Obviously, I prefer the wired connection and could care less if my laptop is Wireless. (Just don't tell that to my Kindle's and BN Nook e-Readers and multiple tablets let alone the Smartphones. We have both Android and iOS devices in house.
Any concerns with one Switch using an Ethernet port on the cable modem and the other Switch using a 2nd Ethernet Port on the cable modem? Something else I should be considering?
I use Norton 360 exclusively in home and while on the road. Should I consider using Armor Bitdefender both in house and while traveling instead or continue using both or just sticking with Norton 360?
Thanks in advance for the advice on compatibility and on Armor products.
John
Guzzialfa wrote:
Yikes! That's a lot of gear! You say it's all behind the one cable modem, CAX80?? I wanted to ask why you disabled the WiFi and just bought a cable modem only sans WiFi with all the routers you have in place? Then, if all hits the fan, you still have a WiFi solution on the Cable Modem just in case, I suppose.
As plemans mentioned, we do lots of playing with toys and learning of what different products do so we can gain more experience to better help users out here in the forums. So we test out different things and different configurations. We also try to test out new FW as it comes out to see what new things are seen. Give feedback to NG and users.
Was there another reason?
Apologies but what is LAG? Don't recognize the acronym but it is 1:15 AM as I type this.
https://en.wikipedia.org/wiki/Link_aggregation
My apologies for the tardy reply as well. You were very quick to respond as well. I just needed a bit to digest all the different replies. No one from NetGear has responded stating these old Switches will be just fine. Should be is what I get from everyone. Then again, I could just do what you've done and get another 4 port Router and plug in the two switches while also disabling the WiFi on the CAX80. It's an alternative should it be necessary.
Your NG switches should work just fine behind the CAX80.
Or is everyone hinting I shouldn't use NetGear's WiFi and not coming out and saying so?
The CAX80s wifi is pretty good. When I have the wifi on my CAX80, since my home is kind of big, I use two EX7700 wifi extenders to help with signal.
Your switches should just connect. I don't have those specific switches but i have both a managed switch and several unmanaged switches. And I connected them to my CAX80 without any specific configuration/settings. All simply worked.
Can I 100% say it'll work? no because everyone's setup is different and I've see people have weird configurations that shouldn't cause a single issue and did. Do I feel very confident it will? yes.
In terms of armor, thats a personal preference. I don't use it but I did try it. It has a 30 days trial period where you can try it and see if you like it. I prefered by own setup versus the built in armor one.
Thank you. I appreciate you having taken the time to respond and apologize for my tardy reply. I read your response as soon as the email came to my phone but do not want to type replies there.
What didn't you like about Armor and what are you using as alternative VPN, Virus Protection/Scan Software etc.?
John S.
Both FURRYe38 and I have more gear than we need. Its more of a testing/playing/learning so we can help others better.
the reason I don't use armor is I've found a combination of using pi-hole and then just good internet practices to be a better result than using a full security suite. I'm sure when my kids get older I'll have to setup something but right now it isn't needed on my network.
You probably won't get a response from netgear as this is the public support forum where members of the public help out. the mod's aren't very active on here
Same here, have different Switches after my CAX80, HP, NG and D-Link. All work fine behind the modem.
My modem is now in modem only mode so I use two different routers behind it. My ISP allows for more than one WAN IP address while in modem only mode. :smileywink:
Hmmm, typing at 1:15 shouldn't be thinking so hard.
Thank you,
John S.
