penridge
Sep 03, 2022Follower
WAC 104
Hi, we have a large house and I find that the wifi upstairs at the opposite end to the incoming router is often weak. I have run an ethernet cable from my TT router into a switch / hub upstairs and now have a wired connection for a PC, a laptop and a network music player. However, I need the wifi to be strong up here as well and I believe what I need is a wireless access point and I have purchased the WAC104 and my intention is to have an ethernet cable from my switch into the WAC104 to extend the wifi. Is my logic sound? I am a pensioner, very much old school and not technical minded in any way? Many thanks, Mike
1 Reply
Sure sounds like it should work.
Just make sure to install it in access point mode (it has a router mode).
And when you set it up, put it on different wifi channels from the main router to prevent interference.
