andcolflu
Nov 29, 2016Aspirant
WAC104 - unable to connect to it to set security
Hi. I have just bought one of these. I have connected it via ethernet to my BT Homehub5 so it works as a wireless access point across the house but I can't access the WAC to set security so ...
- Nov 29, 2016
Hello Andy,
Congratulations on buying WAC104. It is great value based Access point.
Did you configure static IP address on your laptop to be in the same network.
since AP will be @ 192.168.0.100, maybe you can assign your laptop as 192.168.0.101
Can you share your network diagram in brief ? or confirm if your setup is similar to one of below ?
Setup configuration :
Option 1) WAC104 ====One of 4 LAN ports======Laptop ethernetport (192.168.0.101 statically configured)
Option 2) WAC104 ===assoicate to open WIFI SSID ===Laptop (192.168.0.101 statically confifured to wifi interface on laptop)
or put the 104 in your full network.
modem/ISP gateway ====Router=====WAC104 ~~~~~~Laptop
(this is shown better @ http://www.downloads.netgear.com/files/GDC/WAC104/WAC104_IG_EN.pdf
Gateway/Router can be one device and works has DHCP server for the network. gives out IP address to laptop.
WAC104 is an Access point and not a router. So there is no NAT/DHCP server enabled on it.
RaghuHR
Dec 05, 2016NETGEAR Expert
Hi Andy,
Just to followup on this. Are there any further questions?
Thanks
Raghu
