Retired_Member
Mar 01, 2017WAC104: client mode support
Hi, does the WAC104 support the client mode to connect to an existing AP? In the datasheet of the WN604 and the WAC120 I found the info but not in the WAC104 datasheet. If not which Netgear prod...
- Retired_MemberMar 02, 2017
Hi armin_stauber,
WAC104 does not do Client mode. We don't have any AP which has both Client mode and multiple LAN ports.
Alternative solution could be;
1. Two (2) X WAC104 using bridge mode to connect them. One of the WAC104 in place of the existing AP or even connected elsewhere in the network to extend wireless.
2. WAC102 for client mode and a small un-managed switch (GS105) or web managed (plus) switch (GS105Ev2) connecting into the WAC120 to provide the additional ports.
hope this helps
Thanks
DavidGo.
Retired_Member
Mar 02, 2017Hi armin_stauber,
hope this helps
Thanks
DavidGo.
Yes this helps.
Thanks DavidGo!
