a_p_s's avatar
a_p_s
WAC120 - Unable to Edit Set-up
I've got a WAC120 AP that was set-up some time ago and I'd now like to tune the performance / edit security details. My issue is that I can log-on to the admin web-page, see the various tables, but a...
  • DaneA's avatar
    Jan 02, 2018
    Hi a_p_s,
    I suggest you the following below:
    1.  Use other browsers like Chrome or Firefox then check if you are able to edit the settings of the WAC120.
    2.  Use other PCs or laptops to access the web-GUI of the WAC120 then check if you are able to edit the settings of the WAC120.
    3.  If ever step 1 and 2 did not help, reset the WAC120 to factory default settings then reconfigure the settings from scratch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
