a_p_s
Dec 30, 2017Aspirant
WAC120 - Unable to Edit Set-up
I've got a WAC120 AP that was set-up some time ago and I'd now like to tune the performance / edit security details. My issue is that I can log-on to the admin web-page, see the various tables, but a...
- Jan 02, 2018
Hi a_p_s,
I suggest you the following below:
1. Use other browsers like Chrome or Firefox then check if you are able to edit the settings of the WAC120.
2. Use other PCs or laptops to access the web-GUI of the WAC120 then check if you are able to edit the settings of the WAC120.
3. If ever step 1 and 2 did not help, reset the WAC120 to factory default settings then reconfigure the settings from scratch.
DaneA
NETGEAR Community Team
DaneA
Jan 02, 2018NETGEAR Employee Retired
Hi a_p_s,
DaneA
a_p_s
Jan 06, 2018Aspirant
Thanks. A compete reset sorted out the issue.
