PureLoneWolf
Jul 09, 2020Tutor
WAC124 - Empty Response / Access Token Invalid / Resource Validation Error
Hi all Basically, no matter what I do, I cannot get into either of my WAC124 devices to change anything. Fortunately, right now, they are working...but if I have to change anything then I am scre...
- Jul 14, 2020
The problem is being caused by a recent change in Two-Factor Authentication at Negear. If you turn off 2FA on your Netgear Account (I did so on the Insight app), you can access the WAC124's just as you could before. Oddly, I've had 2FA enables on my pair of WAC124's for some time without an issue. I recently needed to login to them and ran into the same issue.
PureLoneWolf
Jul 09, 2020Tutor
Hi
Just to clarify:
Incognito is required to allow me to login via Chrome. The other browsers/devices don't have the same plugins etc all setup - So I suspect my Chrome has a plugin causing an issue there.
Without Incognito on Chrome I can't even login (Resource Validation Error)
With Incognito on Chrome (or non-incognito on other devices/browsers) I can login, verify 2FA with the code sent to my phone, but then I get the blank page with ERR_EMPTY_RESPONSE and a reload button.
If I disconnect the internet from the device and login with local admin, it works OK.
Firmware is 1.0.4.4 on both devices, I realise I didn't mention that before.
PureLoneWolf
Jul 09, 2020Tutor
Almost forgot - I did a complete cache clear on my browser, which fixed the Access Token issue when trying to change my password.
Changing my password did not help the SSO issue however.
- Ronbo2598Jul 14, 2020Initiate
- CarlCresswellJul 14, 2020Initiate
Just wasted a lot of time trying to work out what was going on here as I had run into the same issue on my 2 APs also. 2FA is heavily pushed by Netgear for obvious reasons so it is pretty disappointing that this has been broken. When can we expect an update which fixes this problem?
- PureLoneWolfJul 14, 2020Tutor
Thanks for that - I enabled 2FA from day 1, so I hadn't considered disabling it...:)
RaghuHR Will you be able to pass the 2FA issue up the chain? The moment I disabled 2FA on my account, logging into the devices instantly worked.
It goes without saying that, in these days of data breaches and haveibeenpwned.com being necessary...2FA working correctly is most definitely an important facet of any massive organisation insisting on cloud logins for local devices...wouldn't you agree?
Many thanks
