Iutcal's avatar
Iutcal
WAC124 Invalid gateway IP Address
I am attempting to configure the WAC124 as an access point on my home network. I have turned off DHCP and set the lan to use address 192.168.0.68 in the LAN section of setup. I am able to connect to ...
  • Iutcal's avatar
    Iutcal
    Jan 18, 2022
    So after checking out some more values in the advanced setup menu I found the entry to enable the unit as an access point, no need to go through the rigamarole that is posted on other sites.
    Upgraded the FW while I was mucking about.
    Thanks for the assistance.
ProSupport for Business
