Iutcal
Jan 18, 2022Aspirant
WAC124 Invalid gateway IP Address
I am attempting to configure the WAC124 as an access point on my home network. I have turned off DHCP and set the lan to use address 192.168.0.68 in the LAN section of setup. I am able to connect to ...
- Jan 18, 2022
So after checking out some more values in the advanced setup menu I found the entry to enable the unit as an access point, no need to go through the rigamarole that is posted on other sites.
Upgraded the FW while I was mucking about.
Thanks for the assistance.
Iutcal
FW V1.0.4.6
Resetting the unit it comes up in Router mode. I went to the setup LAN setup screen and unchecked the Use Router as DHCP server and changed the IP to 192.168.0.68.
Iutcal
