DaveLister
Oct 15, 2021Tutor
WAC124 Netgear Account
Need a way to access this device without a Netgear account. Currently I'm forced to reboot the cable modem to knock the down the internet site wide to get local access to the WAC124. Othewise it wa...
- Oct 15, 2021
Yes. It gives any Netgear engineer web access to this device. Also allows monitoring of network traffic. God only knows what else.
Found a solution.
https://download1.dd-wrt.com/dd-wrtv2/downloads/betas/2021/03-04-2021-r45891/netgear-wac124/
schumaku
Oct 15, 2021Guru - Experienced User
DaveLister wrote:
Need a way to access this device without a Netgear account.--- Othewise it wants me to logon to a Netgear account to allow access to setup.
An specific problem with this feature?
You can't disable the cloud login on the AP.
A possible workaround is to block the Internet access for the WAC124 on your router - then it will fall back to the local login.
- DaveListerOct 15, 2021Tutor
Found a solution.
- schumakuOct 16, 2021Guru - Experienced User
None of it. Just because the authentication happens on the cloud it's still only one identity having access. Just conspiracy theories...
- DaveListerOct 16, 2021Tutor
How does Netgear restore your administration password if forgotten as the manual states? Either they have the password or the ability to reset the password. Both are bad.
- Aug 04, 2022Retired_Member
- Apr 16, 2020Retired_Member
