AndyB1974a
Apr 16, 2022Follower
WAC124 unknown error
Can anyone help. whenever i login to my router i get the following message i have tried both wireless and wired and on different browsers
DaneA
Apr 17, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Are you able to access the web-GUI of your WAC124 before just fine?
Have you tried using other browsers or use Incognito mode in Chrome (or In-Private browsing on other browsers)?
Is your WAC124 set to router mode or access point mode?
Are you able to get replies when you ping 192.168.1.100 either wired or wireless connection?
DaneA
NETGEAR Community Team
wac124Problem
May 03, 2022Aspirant
Hello! DaneA AndyB1974a
I have the same issue:
- I reset my router with the pin hole button in the back.
- did default setup (no advanced)
- When i go to 192.169.0.100 I am unable to login into my existing netgear account.
- It looks like the login takes. I do a double verification with text codes
- Then it circles and drops me back to the main page with the same error as above.
Currently my router is in default with a SSID of Netgear-1
- wac124ProblemMay 03, 2022Aspirant
- I have tried in incognito, in chrome + full clear of chache and cookies
- Firefox as well
- Mobile as well
- DaneAMay 04, 2022NETGEAR Employee Retired
Kindly try the steps below:
1. Remove the WAC124 from your NETGEAR Account.
2. Register your WAC124 again when you login to its web-GUI.
Let me know if that fixes the issue.
DaneA
- TankMan535May 10, 2022Aspirant
I have the same problem but I see no way in my NetGear account to remove the product from account.
