dpasadis
Jun 01, 2021Tutor
WAC505: Apple clients (iPhones, Macbook Pros) won't connect with Private Addressing enabled
I can't connect Apple devices (iPhones, iPads and Macs) to my WAC505 that have Private Addressing enabled (randomized MAC addresses). I would like to configure my WAC505 to accept these connections....
- Jun 03, 2021
Unless you have configured some MAC security (random MAC os obviously prohibiting this idea), there is nothing related on these WAC. Possibly your router is out of DHCP pool, has MAC security in place, .... and won't accept these devices.
dpasadis
Jun 01, 2021Tutor
I should add....
The problem only occurs when adding a new device to the network. Devices added previously connect to the WiFI network just fine.
- schumakuJun 03, 2021Guru - Experienced User
- dpasadisJun 03, 2021Tutor
Thank you for your response. It's helpful.
Can I turn on some soft of logging to see why the WAC505 is rejecting a WiFi connection from one specific Macbook Pro? I know the password is correct.
- schumakuJun 04, 2021Guru - Experienced User
Monitoring -> Logs or then the downloaded detailed logs don't unveil anything?
Both the MBP and the WAC505 are operating on curent software/firmware? -> WAC505 Firmware and Software Downloads
Curious, is this an M1 based MBP? How is the SSID configued securitywise?
