swieder
Oct 19, 2021Tutor
WAC505, no https access
When I access my WAC505 or WAC510 access points via Chrome with https://192.168.1.250/AP_login, I get the following error message. Your connection is not private Attackers might be trying to steal ...
michaelkenward
Oct 20, 2021Guru - Experienced User
swiederYour connection is not private
Attackers might be trying to steal your information from 192.168.1.250 (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_AUTHORITY_INVALIDThat looks like one of those browser security things.
Tried a different browser?
Feel free to waste your time by dashing off down an uninhabited bolt hole for the WAC505. But your question really doesn't depend on the hardware. The https thing has has come up for many devices. Given the higher traffic here, this is probably as good a place as any to get help with that issue.
- michaelkenwardOct 20, 2021Guru - Experienced User
My previous reply is a format disaster. Netgear seems to have been playing with the community configuration in such a way that posts get mangled. Apologies for that. There is nothing that I can do about it.
