schumaku
Aug 19, 2018Guru - Experienced User
WAC505/WAC510 5.0.0.17 - Insight Mode - Syslog Control Not Accessible
Hello RaghuHR
Since the WAC505/WAC510 v5.0.0.17 (in Insight management mode) the syslog settings can't be adjusted in the local Web UI anymore, mouse-over does show it as protected:
Afraid, the mouse pointer is not visible. Was this intentionally changed, ie. because of the syslog settings were moved into the Insight App / Insight Web Portal for example?
Yes that is right schumaku. If the WAC5xx is managed by the Insight then syslogs settings can be done via Insight.
Thanks,
Raghu
Network wide setting in the App, indeed.
Somehow I'm always struggling RaghuHR on the Insight Web Portal - what is a Network on the App became named a Location on the portal. And here I can find how to see all locations, add a location ... but always struggling where we can edit a location, e.g. with the global syslog settings. Please advise.
