BretD's avatar
BretD
Administrator
Jul 06, 2018
Insight WAC505 or WAC510 Installations - Post your Pics!
WAC510 Install Video
Do you have a WAC505 or WAC510 Insight Managed Wireless AP? We'd love to see your installation. With its stealthy exterior and super easy to setup and install, did you mount it somewhere clever? Are you retrofitting an existing WiFi Network? Are you powering it with GC Insight PoE Switches? Let us know and post your pics! Thanks for sharing!
I found a nice 50-second little setup video from user Chinese youtube channel wincosupport. Check it out!
  • I just replace an Orbi mesh kit with a WAC510 in AP mode and a WAC505. One is upstairs and the other is in the basement. Both have the same SSID.  I am using local AC power until my POE switch arrives.
    Currently I am using local web management via the device IP address. Will I lose this option if I turn on Insight management?
    I switched from the Orbi due to its inability to run the APs on different wifi channels,
    • RaghuHR's avatar
      RaghuHR
      NETGEAR Expert
      Hi Scott,
      Web management still be available with limited function if you manage your APs with Insight management App.
      Thanks,
      Raghu
      • swieder's avatar
        swieder
        Tutor
        RaghuHR wrote:
        Hi Scott,
        Thanks,
        Raghu
        Thanks. I will stick with web management and keep Insight turned off.
        Are there any settings that are available thru Insight that cannot be accessed thru web management ?
ProSupport for Business
