BretD
Jul 06, 2018Administrator
Insight WAC505 or WAC510 Installations - Post your Pics!
Do you have a WAC505 or WAC510 Insight Managed Wireless AP? We'd love to see your installation. With its stealthy exterior and super easy to setup and install, did you mount it somewhere cleve...
- Sep 03, 2018
There are good reasons to head for Insight and an Insight Premium subscription, like RRM aka. Smart WiFi for example -> How do I use Smart WiFi or Auto-Radio Resource Management (RRM) in Insight?
Managing and maintaining multiple WAC505/510 (as of writing) in Insight is a pleasure, adding more WAC is a snap. I'll never look back to the by-device Web management.
swieder
Sep 02, 2018Tutor
I just replace an Orbi mesh kit with a WAC510 in AP mode and a WAC505. One is upstairs and the other is in the basement. Both have the same SSID. I am using local AC power until my POE switch arrives.
Currently I am using local web management via the device IP address. Will I lose this option if I turn on Insight management?
I switched from the Orbi due to its inability to run the APs on different wifi channels,
- RaghuHRSep 02, 2018NETGEAR Expert
Hi Scott,
Web management still be available with limited function if you manage your APs with Insight management App.
Thanks,
Raghu
- swiederSep 03, 2018Tutor
RaghuHR wrote:
Hi Scott,
Thanks,
Raghu
Thanks. I will stick with web management and keep Insight turned off.
Are there any settings that are available thru Insight that cannot be accessed thru web management ?
- schumakuSep 03, 2018Guru - Experienced User
