BretD
Jul 06, 2018Administrator
Insight WAC505 or WAC510 Installations - Post your Pics!
Do you have a WAC505 or WAC510 Insight Managed Wireless AP? We'd love to see your installation. With its stealthy exterior and super easy to setup and install, did you mount it somewhere cleve...
- Sep 03, 2018
There are good reasons to head for Insight and an Insight Premium subscription, like RRM aka. Smart WiFi for example -> How do I use Smart WiFi or Auto-Radio Resource Management (RRM) in Insight?
Managing and maintaining multiple WAC505/510 (as of writing) in Insight is a pleasure, adding more WAC is a snap. I'll never look back to the by-device Web management.
swieder
Sep 02, 2018Tutor
I just replace an Orbi mesh kit with a WAC510 in AP mode and a WAC505. One is upstairs and the other is in the basement. Both have the same SSID. I am using local AC power until my POE switch arrives.
Currently I am using local web management via the device IP address. Will I lose this option if I turn on Insight management?
I switched from the Orbi due to its inability to run the APs on different wifi channels,
RaghuHR
Sep 02, 2018NETGEAR Expert
Hi Scott,
Web management still be available with limited function if you manage your APs with Insight management App.
Thanks,
Raghu
- swiederSep 03, 2018Tutor
RaghuHR wrote:
Hi Scott,
Thanks,
Raghu
Thanks. I will stick with web management and keep Insight turned off.
Are there any settings that are available thru Insight that cannot be accessed thru web management ?
- schumakuSep 03, 2018Guru - Experienced User
- RaghuHRSep 04, 2018NETGEAR Expert
swieder please refer this KB article about Hybrid Management Mode (HMM)
- schumakuSep 04, 2018Guru - Experienced User
Hi Raghu,
Wouldn't it be wise to add this information abut the HMM including the link (assuming its content will continued to be maintained) with the WAC Web UI instead of the vague pop-up telling about the Insight mode and some greyed out feaures (its more shaded in fact)?
Further on, as the HMM is becoming a part of the design, please add an option to disable this intrusive pop-up.
-Kurt
