yogensenu
Oct 10, 2022Follower
Wac510 access point set up
How do I set up a wac510 access point the instructions where unclear could not find much on line it has a IP of 192.168.0.1 my network use 192.168.1.1 I use the Netgear insight app can’t get anywhe...
schumaku
Oct 10, 2022Guru - Experienced User
The IP address is either assigned by the LAN DHCP server e.g. on the router DHCP server, or it was manually misconfigured into a different IP subnet.
Are there potentially two local networks, operated by two different routers, or assigned to two different IP subnetworks?
