Haaino
May 10, 2021Guide
WAC510 client isolation not working
Hi, I have a WAC 510 with firmware 9.3.0.5. When I enable client isolation I get the following error message: "unable to get gateway mac to configure client isolation!". What does this er...
DaneA
Jun 22, 2021NETGEAR Employee Retired
A new WAC510 firmware has been recently released which is v9.5.1.2. This firmware fixes the issue where the client isolation process stops during bulk configurations and it fixes the issue where the client isolation whitelist table is not cleared when an SSID is deleted or a VLAN is changed.
Kindly read the other bug fixes and download WAC510 firmware v9.5.1.2 here and upload it to your WAC510. Then, check if the same problem occurs.
DaneA
NETGEAR Community Team
