Nana11's avatar
Nana11
Tutor
Nov 07, 2020
WAC510 firmware version 9 cannot use tagged VLAN.
I use WAC510 in local web management, with tagged VLANs to use multiple networks.
However, the WAC510 firmware version 9, all devices cannot access
the network normally in VLANs other than the management VLAN.
It seems that the device can only get an address from DHCP server.
I'm in trouble because I can't use the network as intended.
So, I have to revert the WAC510 firmware to 8.2.7.4 to use the wireless LAN with the tagged VLAN.
I only updated the WAC510 firmware and did not change any settings on all other devices.
I thought it might be a problem with firmware version 9.0.0.21 only, but it was the same problem with 9.1.0.13.
Is it a specification or a bug that the new WAC510 firmware version 9 does not allow the use of multiple VLANs?
If you understand, please tell me the correct answer.
I'm Japanese, so I asked Japanese forum but, no one answered.
So I decided to ask a question here.
I don't use English on a daily basis, so I'm sorry if there are any strange sentences.
  • Nana11's avatar
    Nana11
    Nov 14, 2020
    I was able to successfully self-solve this problem.
    I updated the WAC510's firmware to the latest, did a factory reset and reconfigured everything from the initial settings, but still had the same problem.
    Maybe, but it seemed that some people were using the same WAC510 and didn't have the same problem, so I next checked the operation, changing each setting one by one.
    After doing so, I discovered what was causing the problem.
    The problem was located under Management>Configration>Wireless>Basic>WLAN Settings.
    I found that if the Wireless Client Isolation in the Advanced SSID setting was enabled, I couldn't communicate with any non-Wireless addresses too.
    By disabling this setting, I was able to have network access on any VLAN other than the management VLAN.
    I suspect that the point about not being able to communicate with non-wireless clients and gateways is a bug.
    I'll be using this setting disabled until this issue is fixed.
  • schumaku's avatar
    schumaku
    Hello Nana11,
    Is this WAC510 operating as a plain wireless access point, or do you experience this limitation in router mode?
    Operating bunches of WAC5xx access points on various sites and venues, with at least two or more VLAN and SSIDs. Most are Insight managed (Premium and Pro sites), a hand full WAC are just locally managed. Have a local test set-up with an Insight managed switch and a local managed WAC540 on 9.1.0.13 - and we can't use SSIDs/VLANs off the base/untagged VLAN for the similar reason.
    • Nana11's avatar
      Nana11
      Tutor
      Hello schumaku,
      This WAC510 is operating as a plain wireless access point mode, without Insight.
      My site has three tagged VLANs.
      The VLAN IDs are 11, 2001 and 4040.
      The ID of the management VLAN is 11 and the communication is the same as with previous firmware.
      Clients in VLANs 2001 and 4040 can get addresses from DHCP, but are unable to communicate with the gateway or within the VLAN.
      These also used to be able to communicate without problems, but I had problems accessing it on version 9.
      Is a large VLAN ID number not recommended?
      Or is it not recommended to mix with L2 switches from other companies?
      • schumaku's avatar
        schumaku
        No obvious limitations hit there on the VLANs I'd say. It's all industry standard, using other brand switches should not cause an issue.
        Since updating to v9 firmwares, have checked the configuration of the wired port VLAN config on Management > Configuration > Wired > VLAN ? Ensure all VLANs configured on the WiFi side exist here along with the tagging required.
ProSupport for Business
