hagepat
Aug 09, 2018Aspirant
WAC510 Guest Network
I have 2 WAC510 and 1 WAC505 access-point.
The switches I have are Netgear switches and the router is also from Netgear.
I want to create a guest network. I know that I have to create seperate VL...
- Aug 09, 2018
Hi hagepat,
Welcome to the community! :)
But do I have to create the VLAN on the router also?
Yes, so that router will be the DHCP server for the Guest network. However, if the switch has a function to create a DHCP Pool for the Guest network then configure a DHCP Pool in the switch.
DaneA
NETGEAR Community Team
DaneA
Aug 09, 2018NETGEAR Employee Retired
Hi hagepat,
DaneA
