Stephanfo's avatar
Stephanfo
WAC510 low coverage since last firmware 1.2.5.11
Hi All,   Since I updated the WAC510 with the last firmware (1.2.5.11), I noticed a big drop of the wifi coverage. Any advise before to try to return to the previous firmware to test ?   Regardin...
  • DaneA's avatar
    May 11, 2017
    Hi Stephanfo,
    Welcome to the community! :)
    Did you perform a factory reset on the WAC510 after upgrading the firmware?  If not yet, I suggest you to perform a factory reset on the WAC510 then reconfigure it from scratch in order to start clean using the latest firmware version.
    Hope it helps.
    DaneA
    NETGEAR Community Team
ProSupport for Business
